Model 118 Cap question
I'm working on the above and one of the bakelite caps is a dual .0001 (100pf) cap (Philco P/N 8035K). My question is "would these be mica" and less subject to replacement? I have not seen caps of this value in bakelite enclosures. Thanks for your thoughts (I don't currently have any 100pf caps).
Jerry
I have run into 8035 DG before. There were 2 mica caps inside when I opened it up. So I think in your case they are likely to be Mica's too.
Thank you Chris, that takes the number of restuffs down from 11 to 10! Icon_clap Jerry
If those are in the 2det circuit the value isn't very critical as they use to filter any rf signal out of the detected audio. Anything from 100 to 500mmfd will work fine. When you start to use one than are big you will start to lose the hi frequency response in the recovered audio.
I've seen those with micas inside...but most of them I've opened up had tiny paper caps inside! Icon_eek
You'd better rebuild it, too. Better safe than sorry!
Well dang Ron, you really know how to spoil the party!Icon_biggrin Now I'm back up to 11 to restuff and need to find a couple 100pfd caps. Yes Steve, they are in the second detector circuit appear to be relatively low voltage, would ceramic caps work?
Jerry
I've got some nice 100pf caps on hand. I can send a few to you if you would like.
Brenda, PM sent.
Jerry
My Philco 37-116 Restore
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
There are currently 650 online users. [Complete List]
» 2 Member(s) | 648 Guest(s)
