Philco 40-180 : getting reception but at low volume
I am finally getting some stations on AM broadcast band.
I rewound the oscillator coil with 30ga red magnet wire from Radio Shack.
Now I am getting -4VDC on pin 5 (GT/G3HP) of the 6J8-G converter tube.
Unfortunately, I am not getting any negative bias on the the grid cap (G1HP). I get 0VDC on the grid cap.
I went over the schematic and everything else looks OK. And I am getting some stations with the loop antenna hooked up. But the volume is low.
Does this sound like a case of a bad tube? My tube tester can't test a 6J8-G, so I can only guess that this is the problem.
radlam
I tested the 6J8G at the local electronics retailer this afternoon. The tube tested weak/replace.
All the other tubes were good, so perhaps that is the problem.
radlam
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
First Radio restoration
