Mohawk products/ Philco 645K
Need some info on online suppliers for Mohawk products. Need colors for Philco 645K sides and front/bottom trim.
Thanks in advance, Vernon
Here's one source:
http://woodfinisherssource.com/
I am fortunate to have a distributor 1 mile from work.
Any of these close to you?
http://www.mohawk-finishing.com/find-a-distributor.aspx
Tim
Thanks to that link you sent me I found two within a few miles, thank you.
Shadow Meter Bulb
Model 28L
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
There are currently 4025 online users. [Complete List]
» 1 Member(s) | 4024 Guest(s)
