Philco FM antenna
I have two philcos that I am working on a 50-925 and a 49-906. Both have a bakelite 4 prong plug for FM antenna. How many wires need to be used for a FM antenna andwhy did they do this?
thanks
Chris
In looking at the print for the radio it looks like pins 1 and 4 are the only ones used and also shows some sort of antenna that is possibly capacitively coupled to the line cord on pin 1. Perhaps Philco originally included this line antenna with the set but also allowed for a convenient connection to an external antenna? In any event, I believe most antennas that come with modern day receivers are usually center fed dipole type hence the two connections required. I'm guessing that you could take a modern day dipole type antenna and connect it to pins 1 and 4 on that plug.
That's the Philco rf trap in a foreign radio. Resonant somewhere around the IF, it's a short to ground. You can just rep...RodB — 08:10 PM
I can't believe I missed this little critter when replacing the electrolytics. Wasn't much of him left, he crumbled wh...klondike98 — 06:39 PM
Thx Richard. Arran, the 0.02 caps in mine are also 100v. As I mentioned the original paper tube is just a little small...klondike98 — 01:02 PM
New find. 91X code 225
Nice job there. A very distinguished looking radio. Would like to see a photo when done with added light. Paul B.Paul Philco322 — 12:27 PM
Thanks all. Yeah, I was motivated to do this one and they're generally easy to work on. I don't do a lot of early-'30s...pdieten — 10:22 AM
Hello Bob, What nice looking set it looks like a Emerson that I have you did great job with the two Electrolytic cans ....radiorich — 02:04 AM
Hello Paul, Well, done it looks great ! Sincerely Richardradiorich — 01:55 AM
Congratulations, Paul! That was quick...you made short order of that chassis restoration! And no coils to rewind...bonus...NostalgiaRadioTime — 01:07 AM
Bob; I was thinking the same with that 150 ohm resistor, put a larger value replacement in it's place to compensate f...Arran — 01:02 AM
And the chassis is all done, all caps and bad lamp wiring replaced, power switch repaired and in place, dial string tune...pdieten — 12:37 AM
