RCA 8X71-Hum
I've got a strange one. All electrolytic and wax caps replaced. Resistors replaced as necessary. Tubes tested. Set aligned on both AM and FM.
The problem is that I get a hum on AM only and only when on a station. In between stations on AM is silent as well as FM.
Any thoughts?
Eric
Schematic:
http://www.nostalgiaair.org/Resources/251/M0015251.htm
Eric
The Villages, FL
Selective hum like this is usually environmental. Try moving the radio to a different area of the house and see if it goes away. My workbench is insane for reception problems. There's some kind of field there that creates a ton of RFI, but if I move the radio under test off of the bench, even just a couple feet, all the noise goes away. Before I discovered this, it nearly drove me mad trying to figure out what was wrong with the radios. Icon_smile
Agree, try moving set around. Most likely a really old dimmer, imported unshielded power supply, shut your bench down completely first.
Thanks BrendaAnnD, out of the basement and away from my bench the hum is minimized. It's just strange that this is the only radio that I've had this issue with.
Eric
The Villages, FL
48-482 rear panel help
Hi Kettlechip and welcom to the Phorum. The back panel question is interesting. I have quite a few radios that use pow...MrFixr55 — 08:24 AM
Not too much at all! :lol:  Sounds like you’re just dabbling into the hobby!jrblasde — 07:56 AM
Hi Joseph, Fortunately, Ms. Fixr does not read my computer, or she would warn you against coming to me for sanity ch...MrFixr55 — 07:27 AM
There's a picture of one of the plastic covers in the following thread: I bought a full set of them in 2012 or so fro...klondike98 — 11:15 PM
Good sanity check! You are correct—the first (as in, the most counterclockwise) position is for the push button presets....jrblasde — 11:05 PM
Hi Joseph, First, verify that your band selector is in the correct position for what you want to do. I believe tha...MrFixr55 — 10:59 PM
Got my replacement signal generator in the mail today! I was able to finish alignment of the IF section. I’ve got some t...jrblasde — 09:58 PM
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
There are currently 247 online users. [Complete List]
» 2 Member(s) | 245 Guest(s)
