Philco newspaper articles 1940
Here is a copy of a newspaper page from 1940 I ran across, describing the latest features of the 1941 Philco models.
Although it seems like all the writing was done by Philco's marketing department, there are some technical details among the hype. The advantages of the XXL (triode) mixer are discussed, along with the benefit of two IF stages, and the intermodulation problems sometimes caused by an RF amplifier stage. The beam of light phono pickup is also mentioned.
A little hard to read but interesting nonetheless.
http://fultonhistory.com/newspaper%2010/...200628.pdf
I love this kind of stuff, thanks for sharing.
Yes, thanks
Yep, just like the Philco PR dept. sent them. But that's okay. We wouldn't know it if they hadn't done it.Icon_razz
Using twin triodes as a mixer and oscillator seems to work quite well, though I don't have any sets that use the XXL tubes I do have two AC/DC sets that use an XXD/14AF7. What I can't understand is why they decided to use a triode as a mixer, maybe another patent royalty dodge? I also can't figure out why they used a silly designation for a tube like XXL or XXD, that must have been the marketing department's idea just to make them sound mysterious then just calling them 7A4s or 14AF7s.
There is some legitimate technical basis for using a triode as a mixer. In general, the lower the number of grids in a tube, the lower the internally generated noise, called partition noise.
RCA did some research in the late 30's and found that multigrid tubes like hexodes and pentagrid tubes were the noisiest, followed by pentodes, and triodes being the quietest. So using a triode as the converter results in the lowest internally generated noise level. It is interesting that while RCA did the research, Philco actually put it into practice in their 1940's sets.
As to the XXL name, it seems that it was pure marketing. This way
Philco could claim that they were the only one using this particular "special" tube. Anyone could use a 7A4, but no one else had the "XXL".
http://www.radiomuseum.org/forumdata/use...e_TEXT.pdf
I thought the XXL's were for big guys like me!Icon_lol
Tim Would mounting he transformer vertically change the hum, if used without additional parts? Also, in these amps...morzh — 02:25 PM
Shadow Meter Bulb
Gary I doubt it would introduce any noise. We use similar lamps for the panel indication, 12V AC lamps: they are LEDs...morzh — 02:15 PM
Shadow Meter Bulb
Not sure if anyone has tried this but there are 6.3 volt miniature lamps in bayonet and screw-in base options available ...GarySP — 11:31 AM
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
There are currently 7972 online users. [Complete List]
» 2 Member(s) | 7970 Guest(s)
