37-675 re-cap
Hi Guy's,
Looking at re-capping my 675 chassis, and noticed that electrolitics are not marked as far as voltages on the schematics.
Does anyone know what the corrct voltages are, or can I just use 450 volt for all?
murf
Those on my Philcos were mostly 475V but I use 450V across the board so far.
If you are looking at the rectifier filtering cap and B+ caps.
I think that 450V caps will be fine, as the new caps handle voltage better.
BUT... you might want to actually measure the V present there to be sure. Since house voltage is now in the 120-125V range the actual V present may be much higher than what is was using 110 or 115V that the set was designed for.
The solution IF this is true is to either use 500V or 600V caps OR use a system to reduce the voltage going into your set to 110-115V.
Got it.
Thanks for the help.
murf
How about the odd value dogbone resistors?
I have found that some of them are not available in the value specified on the schematics.
Is it ok to go to the next lower or higher value, or do I have to stack them to get the closest value?
Still learning a radio at a time.
murf
Should be ok. I think the resistors in the set are 20 percent so that give you a pretty good range to choose from.
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
There are currently 779 online users. [Complete List]
» 2 Member(s) | 777 Guest(s)
