Model 37-62 Electrolytic Connection Question
Threads: 2
As I am nearing completion of restoring a 37-62 radio, I see that the 10 ufd electrolytic capacitor is wired with the positive (+) connection grounded. I would like to hear why that was done for this Philco design. Does it have anything to do with the connection to the 6F6 output tube grid and its bias?
Threads: 573
It is in many designs.
The reason is because it is between the Rectifier's negative and the GND, and the rectifier's negative is ALWAYS THE MOST NEGATIVE POINT in any schematic, so everything else is positive relative to it, and so is the Chassis.
Threads: 2
Thanks for the reply. That helped and is what I assumed, but I am really curious about what this capacitor is doing in the rectifier circuit. Perhaps I need to brush up on rectifier circuit design and filtering (?).
Threads: 18
My response was redundant.
(This post was last modified: 06-15-2013, 03:49 PM by codefox1.)
Threads: 88
City: Tacoma
It's "C" supply filtering. (B-) for bias.
Threads: 573
LenH
It has little to do with rectifier design. They simply need a negative bias and so the rectifier negative through resiztor creates negative voltage towRds ground and this cap simply filters it. In some schematics it is left unfiltered.
Threads: 9
City: Vieques, PR USA
State, Province, Country: PR
Lesson. Ground, negative and chassis are not always the same and the terms are not necessarily interchangeable.
Threads: 573
"Ground" which is in systems without separate chassis Ground is the same as the "chassis" is defined as "0V common reference point". It is not negative or positive. It is the common return or common reference.
For example in a typical by-polar Op Amp schematic there will be two power supplies, Positive and Negative, such as +/-15V. GND is simply the common reference there.
Threads: 54
"Does it have anything to do with the connection to the 6F6 output tube grid and its bias?"
Yes it does, the most negative point in an AC radio is the center tap of the power transformer. So the way they developed the bias voltage was by connecting a large wire would resistor with taps, or series of resistors, to the center tap to make everything else more positive with respect to the center tap including the chassis, the chassis would usually be at the end of the resistor network.
This is a fixed bias supply and was very common in pre war AC radios. So to an electrolytic cap the chassis would be the + side and the center tap would be the - if one was installed there. Later on they used a paralleled resistor and capacitor between the cathode of the power output or other tubes and the chassis to make the cathode more positive with respect to the grid.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM |
Arran,
Thanks for checking you manuals.
I appreciate that. Let me know what you find.
PhilPdouglaski — 08:46 AM |
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM |
Philco model 40-100
Greetings;
Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM |
Philco model 40-100
Greetings;
I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM |
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM |
Hello, Richard
the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM |
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM |
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM |
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM |
There are currently 2316 online users. [Complete List] » 2 Member(s) | 2314 Guest(s)
