Model 620, resistor failed
Hi;
Was finishing up recaping the 620 when part 49, 20,000 resistor broke. Does any one know what voltage rating it should be and where I might get a replacement. Thanks.
God bless,
Dave
Hi David,
Think you really want to know the wattage not voltage rating. Appears to be a 1 watt resistor based on the physical size in pictorial drawing but go with a 2 watt since it will look better. Closer to the same size of the original.
Richard
Richard:
Thanks, ordered one yesterday from Radio Daze.
Philco 60 Power Trans
Hello, The HV winding on the trans is about 700 volts no load. My meter (Fluke 115) only reads to 650 volts so I meas...dconant — 04:18 PM
New find. 91X code 225
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
Nice grab! It appears to be a 19X cabinet. This wasn't unusual. Philco often retrofitted to other cabinets as invento...GarySP — 12:32 PM
I would certainly write down step-by-step the progression of disassembly of the works, and probably cuss out the electri...GarySP — 12:18 PM
Nice looking! This annotated schematic from our library shows parts that are slightly different in the early and later ...klondike98 — 11:33 AM
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
That's got to be one of the tightest conglomeration of components I've ever seen! I wonder how the line workers felt bu...GarySP — 05:46 PM
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
There are currently 1510 online users. [Complete List]
» 2 Member(s) | 1508 Guest(s)
