How many Philco 38-116 radios are out there?
Tim: did you recap the RF deck on your 38-116??
If you didn't an easy way to do it is to remove the bandwitch shaft it is held in by 2 screw on the front unsolder the grounds of metal shields and remove the screw that holds them in then you can move them around to get at the caps.
Tim, What are you saying? Should I try swaping out the 6A8G tube? If that is what you think would make the radio tune better I will give it a try... I will try to locate one.
Or you can use 6D8. As long as the filaments are in parallel to each other.
I have one--works and looks great. My favorite Philco in my collection. Ken
Picked one up last summer from a barn.
Looks great and complete. Still on my to-do list
I did remove the RF deck and recapped it; I also had to clear a short on the RF section of the bandswitch.
John, does your radio go dead on the low end of the BC band? A weak 6A8 can cause that problem.
Tim KA3JRT
Tim...Yes it does.....I guess I have to change out that tube and work from there. I really should invest in a tube tester. Where do you guys go to buy replacement tubes?
When I need tubes, I always go to Bob Dobush at Findatube.com:
http://www.findatube.com/
Bob is one of the best guys in this hobby, and he offers good service and some of the best prices around.
+1. Bob has always done me right.
O.K. Thanks guys will go to his website to check it out!
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 858 online users. [Complete List]
» 1 Member(s) | 857 Guest(s)
