Newbie, Philco H865
Hello all, new to the "Phorum." Not sure if this is the right thread section if not bump it to the right one. But over the weekend I picked up a record console of Craigslist. Was trying to look for an Owners manual for it or any kind of info. Its a Philco Ford H865. Has the AM/FM, 8 Track, and Record player. Anyone know what year this is from? Also I need to replace the needle for it as it was broken. Any help would be appreciated. Thanks!
"H" indicates 1960, however I do not show H865 in any of my literature. Console stereos of the era normally had 5 digit model numbers. A letter followed by 4 numbers, possibly a couple of additional letters for cabinet finish. Eight track indicates something later than 1960. Take another look.
A needle or cartridge number will help finding a replacement. The changer could be a VM, Glaser-Steers or BSR. Without an accurate model #, a photo of the changer will help.
Don
I did find the player is a BSR C123-B1. I have the player part at a shop trying to find a cartridge and needle for it. I also found a tonearm on ebay that matches if he cant find anything
This is the sticker on the back of the unit
It appears to be a Canadian number. I have no information on Canadian Philcos. Perhaps others can help.
Excited. The shop I took it to found a cartridge and needle for it! He'll order it tomorrow.
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1082 online users. [Complete List]
» 2 Member(s) | 1080 Guest(s)
