Output transformer for 41-280 radio
The 41-280 I am restoring has a bad audio transformer. Both ends of the input side are open relative to the center tap, and to each other.
I had a post on the Wanted forum, looking for a replacement transformer (Philco part number32-8120) without success. Having exhausted my other sources I am now thinking about a generic replacement. If anyone does have a good 32-8120 transformer I would definitely be interested in buying it.
For a generic replacement, below is my analysis of what's needed, and would appreciate critique if I've got it wrong:
The speaker measures a 5 ohm dc resistance, so I'm considering it 6 ohm impedance (1.25 multiplier suggested by a reference on radioremembered.org). The Philco 41-280 uses two type 41 output tubes in a push-pull circuit. The Type 41 tube spec I googled (Tung-Sol Lamp Works Inc, 1950) has a Typical Operating Conditions and Characteristics table for both Class A and push-pull circuits, and lists plate-to-plate load resistance as 12K ohms. So 12000/6 = 2K impendance ratio, and a 45:1 turns ratio. The Philco 41-280 specification lists audio output of 2 watts, so I'm thinking a 5 watt rated transformer should be OK.
This seem about right?
This looks about right. If you decide to go with the Hammond universal push-pull replacement it looks like the 125B rated at 5 watts would be the one you may want. Radio Daze sells these. John
Unidentified Philco Bakelite
Looks like a Tropic of some sort.morzh — 04:26 PM
The knobs I would guess are not original. PaulPaul Philco322 — 04:14 PM
This unit just became available on a local Canadian marketplace. The seller is unable to find a model number on the back...jrmott2 — 04:03 PM
Ok guys I've corrected the polarity of the area that popped the capacitor and resistor. I do have a question in regard t...osanders0311 — 04:02 PM
Table radio 51C or 52C?
I would love to see the underside of that set, good luck and when you get that all cleaned up and running you will have ...Paul Philco322 — 03:17 PM
>>> Curious how this thing is getting 5V and 2.5V. Not sure I understood. There is that power transformer, it...morzh — 03:12 PM
I have noticed that Marconi cabinets, from that era, didn't really go overboard with the shading lacquer, at least on th...Arran — 02:16 PM
I realize there is a lot of butchery going on here to get it playing. I plugged it in and it didn't play! LOL But al...antiqueradionut — 01:23 PM
I like your approach to the dark finish. IMO to much dark finish hides some of the features of the cabinet. I used dark ...RodB — 12:22 PM
Thanks   I also have some arthritis in my hands, and it is getting a little harder to lift these radio cabinets on and...Dan Walker — 10:01 AM
There are currently 970 online users. [Complete List]
» 5 Member(s) | 965 Guest(s)
AvatarAvatarAvatarAvatar
