philco 46-1201
hi guys
as i have only done 1 recap set so far which turned out easy no problems and worked (lucky) as i bought a 1201 on ebay guy said it worked but weak ya was crappy. arived in yep pices he refunded me got to keep it. some one else had recaped it . powered it up with veriac no shorts or smoke lights up all tubes light. as i can not pic up any am or fm D**n condo i have to use small am transmitter picks up weak and motor boating with sqeals any one have parts locator list ? it has 2 antanna wires coming from tuner and coil both about 6inc long cut just laying ? and last it has a long sqaure block with three wire on it ?
thanks sam
If you go to the Home page on the site you will see a menu heading for Knowledge Base. Under the pull down there is a further menu item for Schematics. On that page you will see a list - if you dont find your model, further down the page is a list of links where you can find schematics. Many of the schematics include tube and parts layouts. But you are on the right track - you need a schematic at a minimum.
Are you sure you don't mean 46-1201? There is no such thing as a 36-1201.
oops sorry 46-1201 not 36
You can find a schematic for the 46-1201 here: http://www.nostalgiaair.org/Resources/584/M0013584.htm and here http://audiophool.com/Philco.html and here http://www.philcorepairbench.com/schematics.htm .
I changed the title of this thread to 46-1201 to avoid confusion.
hi guys
thanks for info maybe this isn`t a good project to start with. i check all seams ok just need 2 more caps to do. i put transmitter right up to tuner picked up loud had to turn tuner all the way to left untill it stoped hads a slight vibration in sound nothing changes when i tap tubes speaker was repaired bad job of it as it is rock hard half way around it`s oval shaped i left on about 2hr seams ok maybe an alignment as transmitter is at 1600 not 500
thanks ron
1600 - 910 = 690 At that spot on the dial you would be able to hear a strong 1600 KHz signal. 500 (more like 540 at the bottom of the dial) would be way off. I see no adjustment for the bottom end. Are the IF's tuned to the proper frequency?
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
There are currently 6008 online users. [Complete List]
» 2 Member(s) | 6006 Guest(s)
