need help identifying a radio
i have kind of been trying to identify this Philco radio. i think it is a 33 or 34 but am not quite sure. i also wouldn't mind knowing what others think it is worth as it sits.
[Image: https://lh5.googleusercontent.com/-vOeiF...AG0981.jpg]
[Image: https://lh6.googleusercontent.com/-lkxFu...AG0982.jpg]
[Image: https://lh6.googleusercontent.com/-F6GWD...AG0983.jpg]
[Image: https://lh6.googleusercontent.com/-mode_...AG0986.jpg]
[Image: https://lh6.googleusercontent.com/-Z-g46...AG0984.jpg]
[Image: https://lh5.googleusercontent.com/-_Bb0k...AG0989.jpg]
i plugged it in and you could see the 2 tubes start to glow and one of the tubes inside one of the metal things started to glow. speaker also was humming.
[Image: https://lh6.googleusercontent.com/-6LP_H...AG0992.jpg]
[Image: https://lh3.googleusercontent.com/-126cK...AG0990.jpg]
Yours looks to be a Canadian 1933 Model 319A which is equivalent to a USA 1933 Model 19L ( see: http://www.philcoradio.com/gallery/1933d.htm and http://www.philcoradio.com/world/images/canindex.pdf ) Don't plug it in again until the capacitors have been replaced, it could damage some of the components.
thanks. i don't think i would really want to plug it in again. i know i won't be replacing the capacitors. i would rather leave it to someone who is more capable of doing this stuff. any idea what it might be worth in it's current state?
In it's current condition, I would guess $40 to $75 at the most.
Jon
Hi Crazzywolfie,
You have a 19L that I have never seen anywhere. Notice how it's all cabinet with very little radio inside? The same cabinet was used for a few larger Philco chassis, such as the 14, 16, 17 and 18.
Is there any chance I could get you to send me larger, and better, photos of this radio? Sure, it needs a fair amount of work in its current condition, but it needs to be documented, and I would really like to be able to show photos of an actual set instead of the illustration currently here:
http://www.philcoradio.com/gallery/1933d.htm#f
I will send you an email on this subject with my email address.
By the way, I concur with Philco281989 on the rough value estimate - it may be a rare radio but it is not highly desirable, plus yours does need a fair amount of work.
Thanks in advance!
thanks. i was almost thinking $20 would get rid of it fairly quick. i know my mom doesn't want it kicking around but i hate through stuff out especially when it could possibly make a bit extra money which i could always use.
is any of the picture i took what you are looking for or would you want something more straight on? if not i could try taking some better pictures tomorrow.
More straight on, showing the entire radio, plus 3/4 views from the left and right, and a shot of the back showing the entire back would be perfect. 1000 pixels or more in width; larger is better. I sent you an email with my email address to send the pictures to. Thanks!
Where in Canada are you located roughly speaking?
Orangeville, Ontario.
ok. i will try to get some good pictures of it. my phone is setup to take photos at 2592×1728 pixels so they should be large enough. when i think i have got some good shots i will email them to you.
I appreciate that, thanks very much! Icon_thumbup
In that case I think your original thinking about a price of between $20 and $40 is about right given the condition. From what people have told me there are a lot of console radios in Southern Ontario.
it would not surprise me. there is lots of history in the southern Ontario area.
[split] New member...
Far as I know, that plastic insulator should be mica. I don't know if plastic is an equivalent insulator.RodB — 10:51 PM
Ok, I think I'm about done.  I've got one anomaly left but other than that, it is working great and picking up lots of s...HowardWoodard — 09:34 PM
Abandoned Zenith 9-S-367 located/Galesburg IL
As I looked through Zillow I noticed an abandoned house for sale in Galesburg Illinois for $14,900. There appears to be...bridkarl — 05:42 PM
Yesterday checked Mouser for the price on some caps and was curious about the mica equivalent. The 27pf 1kv ceramic is 2...RodB — 09:58 AM
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
There are currently 297 online users. [Complete List]
» 2 Member(s) | 295 Guest(s)
