Question re: resistor rating
Hi all,
Just completed the restoration of a 46-427. The only electrical fault was an open resistor. Upon temporarily bridging the resistor with a known good resistor, the radio came alive with a rich, clear sound. The temporary resistor is a 1/4 watt resistor connected by means of jumper leads. I do not know the wattage rating of the original resistor, but looking at the size of it, it appears to be the same size as a 1watt modern resistor. The schematic / service manual does not give the wattage rating. Can I just go ahead and solder the 1/4 watt resistor in place or should I get a 1/2 or even a 1 watt resistor? The 1/4 watt resistor seems to work just fine but I have only had the radio running for 5-10 minutes at a time. The resistor did not seem to be unduly warm or hot to the touch after a few minutes. Welcome any suggestions.
Don
Hi Don
If you have the schematic and parts list, this article on my website should help you out.
http://www.philcoradio.com/tech/resistor.htm
Here you will soon see that the Philco resistor part numbers give the wattage rating (albeit in code as part of the resistor part number).
Addendum:
You didn't mention which resistor, but I figured it out from your posting in that other forum.
R202 - 470K - Philco part no. 66-4473340
The latter part of that part number (3340) indicates that the original resistor was 1/2 watt.
The 46-427 is a nice radio. Good luck with it.
Thanks, Ron! I replaced the resistor with a 1/4 watt one which I had on hand and it's working just fine. The calculations (suggested on the "other forum") indicates that the 1/4 watt is more than adequate for the job. And yes, the 46-427 is a nice radio indeed! has a nice rich sound and a simple, but attractive (at least to me) cabinet.
Don
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
There are currently 536 online users. [Complete List]
» 1 Member(s) | 535 Guest(s)
