37-84 whistles
Working on a 37-84 after fighting all of the crap a previous repair person left in it, I went for the power up. all I get is whistles in certain places on the dial that cannot be controlled by the volume control. I am going to peek at the osc coil primary ans see if it is toast as it has been on many others I have read about.
I have rebuilt all bakelite blocks, replaced the filers and replaced out of spec resistors.
anything else?
Ok so if I am reading schematic right the coil is good on both primary and secondary and show no signs of corrosion. , However I did not find all the crap from previous repair man. I keep finding bad bad solder joints. They had clipped components instead of unsoldering then just tack soldered back to post so the joints break off. I am wondering if they used acid core solder as well.
Don't forget to check the regeneration control - if advanced too far clockwise, the set will go into nothing but squeals and oscillations on every signal.
OK that may be it I can pick up my transmitter in the house good and it sounds good, any other signal squeals.
Yep that was it. I can pick up 1560 good as well. I need a longer antenna to really test it. I had never seen so may broken solder joints and cold solder joints in my life.
Good deal! Icon_thumbup
Remember, when you attach a longer antenna, that you will need to readjust the regeneration control.
Did the alignment on it and now I get 1 more station 1450. I can barely hear 920 and can't hear 570 at all. ( the other local stations.) i will keep the regen control tweeked as I add antenna. this seems like a hybrid TRF/superhet set. have not tried longer ant yet
The 37-84 isn't the hottest iron in the fire but it should easily pick up all your local stations. Keep digging!
Ok a little more alignment tweeking and i have all the locals. longer antenna will help. (using less than 10 ft)
[Image: http://i7.photobucket.com/albums/y295/de...f2a30d.jpg]
Here is an example of the BS I fought in this set. Someone had cut the lead close then tacked it back. when you touched it the solder connection would break. I found this type of stuff on the wires hooked to the bakelite blocks the wire had been cut then tacked back on. I had to clean no telling how many cut wrapped wires off the leads on the bakelite blocks.
Thank the Lord the technician was not s doctor.
btw this went home with it's owner this last week. it was their grandfather's radio. Boy did they enjoy seeing it work.
Gilfillan Brothers Car Radio?
Greetings Phorum members, Hope you can help me identify this type of wire in the photo I have attached.  I am not sure ...georgetownjohn — 01:53 PM
Philco 60 Squealing
Philco 60 Squealing
