Threads: 113
City: The Villages
I just got a GE radio with a ballast tube. I've never seen one(or heard of one) and was wondering how to test it.
I did some reading about it but couldn't find a test procedure. Any ideas?
Eric
The Villages, FL
Threads: 88
City: Tacoma
What's the number of the ballast?
Threads: 113
City: The Villages
It's a BL42B
Eric
The Villages, FL
Threads: 573
Eric
You simply measure resistance between the pins where the resistors inside the tube are connected to.
It is that simple.
Threads: 88
City: Tacoma
These ballasts are available from several sources for about $12. Looking at the schematic, I see that pin 3 to pin 7 should show continuity. Pin 7 to pin 8 is the dial lamp connection. To check both sections check from pin 3 to pin 8, then from pin 8 to pin 7
Threads: 113
City: The Villages
Thanks, B A, I'll check it out.
Eric
The Villages, FL
Threads: 113
City: The Villages
Well, you were right. No continuity at all. I opened it up just to see what it looked like and found broken wires inside. Has anyone put resistors inside the metal tube instead of replacing it?
Eric
The Villages, FL
Threads: 113
City: The Villages
B A, where did you see them advertised?
Eric
The Villages, FL
Threads: 88
City: Tacoma
Threads: 113
City: The Villages
Thank you. It will be ordered tomorrow.
Eric
The Villages, FL
Well, maybe - maybe not :lol: It's been an interesting project so far! Something so simple, yet so cranky. The 1st one ...TV MAN — 05:12 PM |
Haven't thought of Burgess batteres in a while
https://www.radionostalgia.ca/lib/Images/battery/us/burgess1D.jpgi
...Vlad95 — 03:50 PM |
Measure the voltages first, just in case.morzh — 02:19 PM |
Haven't thought of Burgess batteries in a while Mr. Fixer. Boston Edison always used Burgess in their Bright Star yellow...Paul Philco322 — 02:17 PM |
Thanks Sam. I'll let you know. I can probably scare some up from the local radio club.klondike98 — 02:07 PM |
Philco 89 Code 123 Osc Coil
Hello,
I thought I would post my findings on my bad oscillator tickler coil. There were 27 turns on the outer coil b...dconant — 12:38 PM |
Thanks Morzh. So it appears I did wire it incorrectly and I have to switch the wires between pins 2 and 4.bobclausen — 09:24 AM |
No, it's not a problem, just during certain condition it could show up.
Yes, an internal tube short could do that too.
...morzh — 09:13 AM |
You sound guys are never satisfied. :crazy: :clap:RodB — 09:10 AM |
I got some new ceramic octal tube sockets installed and also tried some different coupling caps.
The results:
The go...TV MAN — 08:42 AM |
There are currently 1303 online users. [Complete List] » 2 Member(s) | 1301 Guest(s)
