Philco 39-45 Push Buttons
Threads: 22
City: Chattanooga
State, Province, Country: TN
Anyone have a recommendation for reproduction pushbuttons for this model?
Here is a picture of the originals, which are slowly disintegrating:
[img] [Image: http://i145.photobucket.com/albums/r233/...52_945.jpg][/img]
Threads: 242
City: West Bend, Wisconsin
You can find reproductions here: http://www.renovatedradios.com/parts.html
Scroll down about mid-page.
Threads: 22
City: Chattanooga
Thanks a bunch. those look like the exact part.  I just ordered a set.
While I'm at it, does anyone know what the original pilot light lens and door knob look like?
(This post was last modified: 08-24-2013, 06:29 PM by Eric T.)
Threads: 6
City: Grand Junction, CO
I understand the new ones don't need the brass clip, and that you can trade your old ones in for $1 each. I have a 39-45. Do you have pics? What are you using for grill cloth, assuming yours had to be replaced.
(This post was last modified: 08-26-2013, 12:37 PM by audiomagnate.)
Threads: 22
City: Chattanooga
After looking at the originals again (they were in a plastic bag when I bought the set), I'd recommend keeping the brass clips. You probably won't need them, but they'll keep the buttons from falling all over the place while the brass faceplate is not fastened to the cabinet.
Here's a pic of it:
[Image: http://i145.photobucket.com/albums/r233/...3139_n.jpg]
This radio has the original grill cloth, and the cabinet is in excellent shape. The only serious imperfection is a bit of the veneer about an inch square chipped off the back edge of one side. The speaker looks like it's new, but it's the original. Electronically, it is also in excellent shape. The power transformer doesn't even run hot even though my house electricity runs at 126 VAC. The biggest issue is that one of the pre-set station coils is missing.
Also, I think this set is one that has the etched dial glass that makes it easy to re-do the white lettering.
(This post was last modified: 08-27-2013, 08:19 PM by Eric T.)
Threads: 6
Threads: 22
City: Chattanooga
Should be able to see it now.
Threads: 6
Very nice! I need to get motivated to do something with mine. I have a love/hate relationship with the looks.
Threads: 22
City: Chattanooga
I love the performance of this set, but the looks leave me flat. I'm hoping that getting it looking as original as possible will help.
The repro buttons should arrive tomorrow. I'm still trying to figure out what the pilot light jewel looks like so I can get a replacement. I'm also looking for an original cabinet knob.
The original jewel was made of Tenite, which is infamous for warping and shrinking over time. I *think* the originals were more or less flat with a slightly concave surface, red in color.
Threads: 6
I wonder what people thought of that style when it came out. Most people that see mine think it's from the fifties.
Threads: 22
City: Chattanooga
Well the buttons have arrived.
First impressions: the visible portion looks great. The plastic on the back half of them is a little softer, though. I transplanted the brass clips into them and put the buttons into their slots on the faceplate. I'm just guessing how they go in-- clips down, right? The buttons are exact matches for what's left of the originals in size and shape. They seem to be a bit loose and sloppy, though. Maybe I've got them in wrong.
Anyway, here it is:
[Image: http://i145.photobucket.com/albums/r233/...52_723.jpg]
[Image: http://i145.photobucket.com/albums/r233/...14_130.jpg]
(This post was last modified: 08-29-2013, 09:17 PM by Eric T.)
Threads: 6
Too bad they are loose. They look good. I'm jealous of your original grill. Are you going to try to clean it up a bit?
Threads: 22
City: Chattanooga
Here's some pics of the actual buttons.
After transplanting the brass clips:
[Image: http://i145.photobucket.com/albums/r233/...1377917533]
Back side view of the buttons in their slots in the escutcheon:
[Image: http://i145.photobucket.com/albums/r233/...1377917525]
Again, I'm just guessing how they go in, based on the wear patterns inside the slots. They were already removed when I bought the radio.
Audiomagnate: I have considered cleaning the grill cloth, and will do it eventually. I want to find the least destructive method first, since it is in such good physical shape.
(This post was last modified: 08-31-2013, 08:08 AM by Eric T.)
Threads: 6
I just wonder if dry cleaning would be the way to go.
Rogers Majestic R-646
Vlad;
I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM |
Thanks RpdB
I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM |
Vlad;
I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM |
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM |
By the way, the bypass you suggested is a rare solution in some circuits.
For example, this schematics solution is used...Vlad95 — 01:43 PM |
No, you are wrong, because you did not know the details.
Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM |
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM |
Thanks RodB for the help.
But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM |
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM |
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM |
There are currently 1025 online users. [Complete List] » 3 Member(s) | 1022 Guest(s)
