Trying to clean knurled knobs from 37-116
Threads: 554
City: Jackson, NJ
I tried as we usually do it to mix a liquid dishwashing soap with hot water and soak the knobs and then scrub it with toothbrush.
Zero effect on that gummed up skin oil plus dust......it is lodged well.
A sharp object will take it out but I do not want to scratch the backelite.
Are there any solvents I could use?
WIll GoJo do it? I would use it but I do not know if it affects the backelite in an adverse way.
Threads: 92
City: Clayton, NC
No, GoJo is fine to use for bakelite knobs.
Set the knobs face down in the GoJo for a few minutes, then scrub with a toothbrush.
City: Kentucky
Toothbrush and alcohol works for me. Bakelite is almost indestructible. Once you get them cleaned up, you can spritz them with some clear lacquer if you want to make them look brand new.
(This post was last modified: 09-08-2013, 03:22 PM by Jamie.)
Threads: 89
City: Tacoma
See my post in the other thread about Simple Green.
Threads: 8
City: Central PA
I used Goop (same as gojo) and an old toothbrush. Worked very well! I'm contemplating a light coat of lacquer as PuhPow recommended.
Threads: 54
City: Lexington, KY
I've had very good luck letting them soak in a heavy spray of furniture polish (Pledge). The grime seems to come right off with a toothbrush and the polish shines them up. Go-Jo or Goop should do well also, and any treatment might take more than one application. The sharpest thing I would try using as a last resort is something like a wood toothpick.
Threads: 554
City: Jackson, NJ
I did use toothpick, otherwise anything metal scratches it.
Threads: 268
I think I read somewhere alcohol is not a good thing to use on Bakelite like ammonia it can irreversibly dull the finish of the Bakelite. Some folks use shoe polish on them to get the shine back after cleaning with something too harsh. Easier and less toxic than lacquer. I bought a can a while back and was really surprised how much it cost. When I was a kid it was 10 or 15c at the drug store now it's like 3.50-$4 !!!!!
Threads: 554
City: Jackson, NJ
Those 4 I tried initially to clean with Windex (and then you told me not to) do not look any different than the 5th one that I did not touch with Windex and only used GoJo on it.
All 5 are not exactly shiny but are OK.
PS. I hate laquers on things it is not intended to be on. Eventually it cracks and peels and scratches. Like those stainless steel fridges with "no fingerprints" because they aree simply covered with some varnish or laquer. It scratches and then looks worse than any smudged stainless steel which, BTW, you can clean in a jiffy with that cleaner they sell for it.
Threads: 92
City: Clayton, NC
After you have the knobs clean, try going over them with some metal polish. After you are done wash the excess polish off with soap/water.
Threads: 55
City: Evanston, IL
My elixir of choice is Krud Kutter, in the red container and soft toothbrush.
Chuck
Threads: 54
City: Lexington, KY
Quote:Those 4 I tried initially to clean with Windex (and then you told me not to) do not look any different than the 5th one that I did not touch with Windex
I've never tried Windex, but 409 cleaner severely dulled a set of Bakelite knobs on me a long time ago. Since then I've never had to go any stronger than a good soak with spray Pledge.
Agree with TA on the metal polish if needed. I had a pretty dull Motorola 56H and my (current) favorite metal polish (Satin Gloss) made the cabinet and knobs look like new.... I was impressed.
Threads: 13
City: Ambler, PA USA
Hot water and a denture cleaning tablet like Polident works for me.
Mike Koste
Gobs of Knobs
Zucksville, PA
Threads: 25
City: Lebanon, NJ 08833
I clean my knobs with steel wool and Dawn, using a tooth brush to get the crud out of the grooves. This dulls the surface but gets all the dirt and oxidized plastic off. Next I buff the knob with tripoli on my buffing wheel staying away from any knurled or fluted areas and being careful not to press too hard which generates heat and could melt the plastic.
After polishing with a soft cloth to remove the buffing compound residue I wax the knob with carnauba wax. Did this technique on over 20 radios with excellent results:
http://galleries.shacknet.nu/steves/gall...que-Radios
Steve D
identify very thin wire for replacement on 37-640
Thanks so much for your help! I really could not have gotten this far without the kindness of you and other members. T...georgetownjohn — 11:50 AM |
Philco 38-7 Oscillation
Will do, thank you.tludka — 10:26 AM |
As to your oscillation issue I would align the IF transformers. That may solve the problem. You also would want to check...Radioroslyn — 10:22 AM |
Philco 38-7 Speaker
Thank you, I will check this out, I do have some shields I can place around the specific tubes. I searched the four que...tludka — 10:18 AM |
Philco 38-7 Speaker
Also, check if any wires going to Grid Caps of the tubes that are supposed to be INSIDE of their respective shields (if ...morzh — 09:54 AM |
Usually in this forum, when we discuss a radio, we do not multiply threads. You already have a thread on this.
If you wa...morzh — 09:27 AM |
You can possibly use a heatshrink tubing.
If you decide to replace the wire, anything gauge 24, 300V rated will do (it ...morzh — 09:25 AM |
Happy Thanksgiving,
I have attche a photo of a very thin wire with black plastic-looking insulation(some of it has com...georgetownjohn — 09:14 AM |
Philco 60 Squealing
I got my signal tracer out to see if I could tell at what stage the squeal was coming from. It is present on the plate o...dconant — 09:07 AM |
Philco 16B Parts
The 16B's in the tombstone cabinet sport a 10 1/2" spkr vs the older cathedral sets which uses an 8". The p/p ...Radioroslyn — 12:58 AM |
There are currently 3574 online users. [Complete List] » 1 Member(s) | 3573 Guest(s)
