Philco 024 Signal Generator
Threads: 27
City: Boulder, Colorado
Hi All;
I have the Philco 024 Signal Generator, and I have ordered the Papers (Documents) from Chuck for it and they are a week or more away..
But, in the mean time can anyone tell me if there are three power wires or four power wires ?? As near as I can tell I have three wires that I assume are for power, but it could be missing a wire.. Two (I think) of what I have are for the filament one going thru the switch which is missing and I have put in.. The other one of the three is for the +90 Volts, its -side of the 90 volts that I am not sure of.. Does it go to one of the filament wires which would make it a three wire setup, Or does it go to Ground which I would then have a four wire setup and I am missing that wire..
THANK YOU Marty
Threads: 270
I would suspect that one wire is for +90v, one wire is for +2v and the third is for the -90v and -2v together. But relax and the diagram will be there before you know it or damage something by applying the wrong voltage to the wrong wire.
Threads: 27
Hi All;
Radioroslyn, I already know what you have stated, and that was or is why I asked about the correct wiring.. I just thought maybe someone would have the answer before the papers get here.. Patience is not one of my traits.. I hate waiting..
THANK YOU Marty
(This post was last modified: 09-28-2013, 09:06 PM by marty.)
Threads: 270
Ok well tell me where each of the wires connect.
(This post was last modified: 09-28-2013, 09:17 PM by Radioroslyn.)
Threads: 27
Hi All;
That is the 64 thousand dollar question.. I am pretty sure that the Green Stripped wire goes to +90 volts.. And the white wire goes to the + side of the filament voltage (+2.0 volts) and the green wire thru the switch goes to the - side of the filament.. But, the real question is does the -90 volt side go to the - side of the filament as you said, or to ground since there is a tab there next to the switch.. And as you have said I don't want to burn anything up.. I can use a lower voltage for testing purposes, but confirmation would be a better way to go.. I have a partial schematic drawn out..
THANK YOU Marty
(This post was last modified: 09-28-2013, 09:33 PM by marty.)
City: Kentucky
Marty, go lock that signal generator in the trunk of your car.. and don't get it out until the schematic arrives..
If you mess it up, you'll be kicking yourself in the rear..
Threads: 26
City: Hayward, California
Yes, Just guessing and experimenting will probably only get you in trouble. If there are schematics on the way I wouldnt touch any wireing until you get that..If you can't wait, clean it all up cosmeticaly until you recieve the papers.
Threads: 27
Hi All;
Besides drawing out the Schematic, I have also put knobs on the Outside.. Probably not correct, but at least I have something on there.. I have also put in a switch from another old meter that was parts and so the switch looks Origional.. So, I have been bidding my time doing what I can..
THANK YOU Marty
Threads: 27
Hi All;
I got the Schematic from Chuck, THANK YOU Chuck !!
And the Biggest Suprise is that the B+ Voltage was not 90 Volts, but 22 and 1/2 Volts, I don't know where I had heard that it was 90 Volts.. But, now I have the Schematic.. I need to get some Battery Holders from Radio Shack, on a single "D" for the filament and for starters 3 nine volt holders, once it is working I will add another three holders for longer life (Series-Parallel).. 27 volts..
THANK YOU Marty
(This post was last modified: 10-07-2013, 08:14 PM by marty.)
Threads: 55
City: Evanston, IL
Glad to help. Post some pics of the innards.
Chassis underside, rear of chassis outside the cabinet, etc.
Chuck
Threads: 1
City: Portsmouth
Yes the normal plate voltage for a #30 tube is 90 to 180 volts but for some applications 45 volts is listed in the RCA data sheet and in the 024 it uses 22-1/2
Ok MrFixr55,
I have tried the DeoxIT D5 on the band switch and even though it has relieved the tension I felt when turn...osanders0311 — 11:11 AM |
Is there a reference somewhere where you can punch in Philco part numbers and see what models those parts were used in?Jim Dutridge — 10:17 AM |
Hi OSanders,
Look carefully at the band switch. Turn it slowly and "wiggle" it around the desired band. ...MrFixr55 — 12:33 AM |
5U4 vs 5Z4 tubes
I think that RCA and GE introduced metal tubes in the USA in 1936. I don't know if they were being made by RCA, GE or b...MrFixr55 — 11:20 PM |
Vlad95,
Thank you for the stringing guides and wow there are so manyosanders0311 — 06:01 PM |
5U4 vs 5Z4 tubes
A pre war Hallicrafters, and an early one too, very nice! 1936 is pretty early for metal tubes too, which would explain ...Arran — 05:58 PM |
Thanks Rod,
"When you hear the background hiss and no station it usually indicates that the oscillator quit" ...osanders0311 — 05:52 PM |
RodB
:beerchug:Vlad95 — 10:22 AM |
Vlad, you nailed it. Swiss and German roots.RodB — 09:54 AM |
5U4 vs 5Z4 tubes
Well this is a Hallicrafters SX/9 circa 1936.
No real issues so far although I dodged a real bullet with a cap that was...bridkarl — 07:59 AM |
There are currently 1885 online users. [Complete List] » 1 Member(s) | 1884 Guest(s)
