Newbie
Hi..My name is Mike...I live in eastern North Carolina and have recently acquired a Philco 47-1230 !...Excellent shape...It has a D-10A phono...Here's the trouble...The plastic gear is stripped that drives the cam...I'm sure this is a common problem...actually I did it because not knowing any better I turned the spindle by hand to get things moving...Well there went the gear!...I have since taken things apart and cleaned all the old hardened grease off and used 3-in-one oil to make things move nice and smoothly.
My question is...Where can I get a replacement gear?..Thanks for all Your help!...I look forward to talking to the experts!...Any advice You Guys can offer would be greatly appreciated....Thanks again!....Mike
Picture of problem will help. Someone here will be able to encourage/discourage/help you.
We were all new to this hobby once, suggest you change your sign in name to apprentice or whatever.
Thanks...I'll see if I can get a pic up this weekend.....Mike
Cannot get My camera to work...but thanks anyway...I made a gear Myself since No One could help.
Glad you solved your problem. If you post how you made the gear it might help someone in the future.
I simply machined one from aluminum.
Simply put.... Icon_surprised
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
