wax paper capacitor suggestions
what type of capacitor should I use to replace the wax paper caps in my radio ?
I think most of us use the yellow mylar film capacitors...cheap, reliable, and small enough that they may be hidden inside the shells of the old paper capacitors if desired.
Agreed. You can get them from a number of sources, Bob's Antique Radios, justradios.com are two that come quickly to mind.
I also use a number of the radial lead types when not restuffing and when they seem to fit better. The DME-series from Mouser.com is an example.
GL,
Bill
Hi Jerm,
I get mine from http://www.radiodaze.com/ Never had a problem with them and good folks to talk to on the phone. You usually get your parts in 3 to 4 days. Like exray said there are many good places to get caps.
The tubular "yellow caps" and the molded film types will fit inside the bakelite block caps too when you re-build them:
[Image: http://www.philcorepairbench.com/images/bblok-06tn.jpg]
BAKELITE BLOCK RE-BUILDING
Easy Steps to Re-building
I usually place a big order a few times a yr., qty 10 or more of each value of the most-needed "orange dips" & all my electrolytics from some very nice folks (Dave & Babylon Cantelon) in Canada. Very compact sizes of all types capacitors, and have never had one fail in over 8 yrs. Very nice selection also in all voltage ratings & ufs, uufs etc! Very fast shipping & receiving at my Texas location also!! They also accept paypal & have online order form. They usually throw-in a couple extras and some free small heat-shrink as well !! Dave also offers many other parts & services.
http://www.justradios.com Icon_wink Txrockr
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
There are currently 755 online users. [Complete List]
» 3 Member(s) | 752 Guest(s)
