Is this a Philco Grandfather Clock?
I spoke to the seller earlier in the week. If he still has it, I am going to look at it tomorrow as I am there on business.
What I cant tell is which model it is. Its hard to see in the pics, but the grill is different from any other Philco I can find here or online. It has two double vertical grill "slats" on each side where the ones I typically see have one on each side. The face looks a little different from a Model 570 also.
Is this authentic?
http://allentown.craigslist.org/atq/4167806101.html
I took the photo of the front of the set and greatly turned up the luminance so I could make it out.
My vote is for a Phranken-Philco and not a legitimate, authentic set. Looks like someone combined the case of a Philco grandfather clock, the front panel of a Model 60 console, a non-original clock face (probably movement also) as well as a Model 60 chassis and speaker to make an odd combination.
I tend to agree with Ron that
it's a Franken-Father.
Or if you prefer, The Odd Father of clocks.
Decent job though.
Chuck
Thanks, I'll pass on it.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
