Replaced the capacitors but all I get is a hum
#46
Ah... that would do it.
Yes, the speaker must be connected when taking voltages. The field coil is the large coil on the back of the speaker. It has a dual purpose: It serves as a magnet for the speaker and as a filter choke for the power supply. Without that in line, no voltage.
#47
Yes Andrew, as Brenda indicated with the field coil open (disconnected) you will get no voltage anywhere but the rectifier. Need to have the speaker plugged in to give it a chance. The field coil is part of the speaker and the power supply.
Jerry
#48
I recently purchased a 42-380 console at an auction. I replaced all the caps and had the same problem, just a low hum. I took the radio to a local repair person and he found that the output transformer under the chassis was open. We bought a new one and it corrected the problem. The radio works great now.
Charlie
#49
Charlie
I find this story a little strange: if your output transformer is open you should not hear any hum whatsoever. Maybe you could hear the transformer buzz, but there is nothing to make the speaker hum.
#50
Morzh, you still can get a hum because of the pulsating DC flowing through the field coil. The resultant varying magnetic field induces a voltage in the voice coil which causes it to move.
Same concept as an AC induction motor
#51
And that's the reason for that hum-bucking coil that runs in series with the voice coil. Icon_smile
#52
Maybe...if the winding of the transformer that is open is the primary one, yes.
#53
I've never seen an open low-impedance secondary.
#54
Andrew, I am quite curious how this turned out. Did you find the problem? I would really like to know where you got a "capacitor kit" for your radio. I have a model 70 I am working on, and am sure I will need to replace the caps also.
Tim
#55
Welcome. Many times the low wattage carbon resistors have gone way out of spec, and a fistfull of replacements is only a couple of dollars. Do this and report back.
New Philco Repair Bench
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
Maybe this is starting to make some sense in my hard head.  Is this why the wire in question was not in the great Ron Ra...georgetownjohn — 04:34 PM
I was correct with the 6A8 pin connection's, 7 and 8 are connected to ground as well as the tube shield (the broken line...RodB — 02:41 PM
What does the dotted line representing that surrounds the tube in the schematic?georgetownjohn — 02:17 PM
Hello John, I have been there either label got lost or was not labeled ! Sincerely Richardradiorich — 02:15 PM
Sorry, it is a Philco 37-640.  Does that help?--Johngeorgetownjohn — 02:14 PM
