40-201 Speaker Wire Colors
On the schematic it shows that the wire colors for the field coil from the chassis to the speaker are Blue White and Green White. What are the colors for the speaker voice coil high side (+) and low side (-)? I am going to have to replace these wires as they have become quite cracked and numerous spots have bare wires due to handling while I have worked on the chassis.
I would add that I looked up the color code standards for field core speakers and normally solid green color is used for the + speaker wire and black solid color is used for the - speaker wire. In this set, Philco did not use the standard. The existing wires appear to be yellow? and white, beige or brown - I can't tell.
Joe
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
There are currently 1236 online users. [Complete List]
» 2 Member(s) | 1234 Guest(s)
