38-62 Schematic
Anyone have one or know where I can get it. None online available that i can find.
The set of beitmans that I have looks like 9-19 or 9-18, 8-19, 8-18
I have been to all for no bolo.
Help
Thx in advance
Bradley Rush
There doesn't seem to be a 38-62 on Nostalgia Air, but they do have a 37-62. From the descriptions in the photo gallery, it sounds as though the 37-62 might have carried over into 1938 as the 38-62 with little change. http://www.nostalgiaair.org/Resources/211/M0013211.htm
You can no doubt get a 38-62 Philco service package from Chuck Schwark. http://www.philcorepairbench.com/schematics.htm These packages are well worth it.
John Honeycutt
The 37-62 schematic is the same.
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
There are currently 6056 online users. [Complete List]
» 1 Member(s) | 6055 Guest(s)
