Philco 42-365
I'm a new to the forum ...... experienced in electronics, but all post tube era. I acquired a 42-365 when moving my parents from their home to assisted living. The cabinet is in very good condition ...... but would look nicer with a restoration. There is a loud constant hum ( independent of volume) which Ron tells me is likely the electrolytics. I don't see much discussion on this model. Are there a lot of these around? Is it an uncommon model?
http://www.philcoradio.com/gallery/1942a.htm
Not a real common set...but not a desirable one, either, from a collectibility standpoint. I have one like yours, either a 42-365 or 360, don't really remember right now. It was given to me by a good friend...I do not plan to restore it, but will use it for parts. Its cabinet is pretty much shot.
Do replace those electrolytics, and ALL paper capacitors as well. The old rubber insulation on the wiring will also have to be addressed.
Good luck, and enjoy!
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
There are currently 547 online users. [Complete List]
» 1 Member(s) | 546 Guest(s)
