Disintegrated pushbuttons and Bulb "cover"
Hello All,
I am working on a Philco floor model circa 1940-41. The pushbuttons and front light bulb "cover" have dissolved into nothingness. I have found a source for the push buttons but I cannot locate any info for the small piece of plastic that would cover the light bulb hole that is on the front of the cabinet. It is a larger diameter than a pencil but not by much. I hope someone understands what I am referring to and might know a source for the part or maybe a way I could "homebrew" one. Thanks for your time!!!! Phil
Did you look at Radio Daze or Mark Oppat?
Hi,
Yep, I checked those sources too. I am very lucky because I live only 40 minutes drive from Radio Daze. Actually I live about 40 minutes from everything. I'm in a rural area here. Thanks for the ideas. Icon_smile
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
There are currently 759 online users. [Complete List]
» 2 Member(s) | 757 Guest(s)
