Disintegrated pushbuttons and Bulb "cover"
Hello All,
I am working on a Philco floor model circa 1940-41. The pushbuttons and front light bulb "cover" have dissolved into nothingness. I have found a source for the push buttons but I cannot locate any info for the small piece of plastic that would cover the light bulb hole that is on the front of the cabinet. It is a larger diameter than a pencil but not by much. I hope someone understands what I am referring to and might know a source for the part or maybe a way I could "homebrew" one. Thanks for your time!!!! Phil
Did you look at Radio Daze or Mark Oppat?
Hi,
Yep, I checked those sources too. I am very lucky because I live only 40 minutes drive from Radio Daze. Actually I live about 40 minutes from everything. I'm in a rural area here. Thanks for the ideas. Icon_smile
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A...captainclock1988 — 03:43 PM
Philco 42-390, code 121 speaker
Using a 5W  1.5k  ceramic resistor in place of the field coil and using a 4 ohm PM speaker, I was able to bring the radi...Stevelog — 02:57 PM
Philco 60 Squealing
I have taken out the 2nd IF and found a problem or not. I believe the coils are litz wire. There is a very small strand ...dconant — 02:13 PM
Philco 6K7
I am restoring a Philco 37-60. The am reception is very good, but the shortwave is very weak. Run 6 Philco removes the g...bobbyd1200 — 01:35 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A5...MrFixr55 — 06:48 AM
I think it would come under either American Bosch or United American Bosch. American Bosch made sets for the American We...Arran — 05:53 AM
There are currently 6055 online users. [Complete List]
» 1 Member(s) | 6054 Guest(s)
