Model 43 can capacitor
that has 3 caps to ground I'm guessing 2 of one value and one of another based on the wire colors.
Anybody know the values or the Philco P/N of the beast? I want to try to get caps on order Monday so I'll have them by the end of next week
John
Las Vegas, NV USA
Looking at the schematic on Ron's pages http://www.philcoradio.com/tech/images/43.jpg it looks like the 3 electrolytics are 6uF. Chuck Schwark would have all the details which you can order here: http://www.philcorepairbench.com/schematics.htm .
John,
Are refering to item 44 on this schematic?
http://www.nostalgiaair.org/Resources/579/M0013579.htm
If so, it's p/n 05239 which contains 1 - .25 and 2 - .5 caps.
And note the test voltages listed on Chuck's site:
http://www.philcorepairbench.com/metalcap.htm
Carl
Northern Panhandle, WV
LO that will work... was after the can paper block .5/.5./.25
I rebuilt the Marchons Kinda butchered one of them Icon_sad and the .01 blocks and 2 of the .05's (ran out of .047 caps) and it plays some, when it's not going microphonic or acting like it has decoupling problems.
John
Las Vegas, NV USA
Looking at the values on Ron's print it must be P/N 05239
Those voltages look impressive, but I think the tubes would jump out of the sockets long before the caps would fail due to overvoltage. One section is decoupling for the oscillator, one is the mixer and IF's and the other is the screen on the 42
John
Las Vegas, NV USA
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1111 online users. [Complete List]
» 1 Member(s) | 1110 Guest(s)
