Model 70 oscillator coil resistance
what should be an acceptable measurement of the primary of the oscillator coil on a model 70 (<22,000). secondary windings are 6 ohms and 3 ohms. the primary is only 7 windings so should my measurement be close to zero?
As long as it is in units or ten plus ohms limits, you do not have to worry. Typically it is either Ohms or it is open, which is when you have to worry. Goes for all RF transformers.
CT Radio Museum
Hello wjreese, How Cool is that !! I read some history on them and it really sounds like they have nice place and lots...radiorich — 12:27 AM
CT Radio Museum
A great looking museum! Thanks for posting your visit.klondike98 — 11:08 PM
National NC-57 case
I have some of that so I’ll try it. That works great on my Philcos. This radio was a gift from a friend of mine so I’m ...bridkarl — 05:54 PM
National NC-57 case
As far as the cabinet condition, try cleaning it with Goop (non-pumice) hand cleaner and 0000 steel wool. GENTLY! You'l...GarySP — 05:35 PM
National NC-57 case
Yea. I think a repaint is order.  I probably have a spare bandswitch knob somewhere. Since this is an AA-5 type desig...bridkarl — 05:27 PM
Philco model 512
The one I restored had an RCA 100 speaker, the big cast iron one that produced sound from both front and back.RodB — 09:35 AM
National NC-57 case
Not only is the paint chipped out but it has dent that will need to be pushed, or pounded out. The set must have been dr...Arran — 05:09 AM
Philco model 512
There was a 511, (or an updated 1929 model 65 version) Spanish Brown, model in my region, and even though it had obvious...Arran — 06:25 PM
One method that some have used is to get some hardwood dowel, of the appropriate diameter, and cutting a flat onto one s...Arran — 05:03 PM
National NC-57 case
I’m currently recapping this National NC/57. This has a scratch on the case. I guess I can sand this out and just do a s...bridkarl — 01:29 PM
