Not sure if I have to rewire....
I am new to the forum, as well as old tube radios. If I read the other posts correctly then am I safe in thinking that I DO NOT need to rewire my 38-5x, 46-131, or 48-460 radios due to the fact that they were made outside the time when the rubber insulation was used?
Just checking before I pull my hair out trying to rewire everything.
John
Correct...no rubber-covered wiring was used in any of the models you mentioned, save for the AC cords which are probably long gone anyway.
How I happened to get so lucky is a minor miracle. Normally when I start to acquire new hobbies I invariably end up with the one model that doesn't work the same as the rest, or requires something quirky.
I'll count my lucky stars that I dodged that one. Now I just have to make up my replacement cap lists!
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
There are currently 763 online users. [Complete List]
» 2 Member(s) | 761 Guest(s)
