40-180 electrolitic
Looking at the 12/350 electrolitic, and there are a few wires soldered to the mounting nut for the can.
There is what looks like a noncumductive washer under the nut.
There is a red wire soldered on the nut which has 13.5 volts going thru it from a terminal strip close by as well as a green wire(I think its green) from the transformer. There is also a resistor mounted to this nut which goes up to a terminal strip.
Is this just a tie point for the wires or do they need to be connected to the negative side of the new electrolitic.
Kind of confused on this one?
murf
Those wires, and the nut, are connected to the can of the capacitor. The insulating washer is to keep the can negative above chassis ground for the bias section of the supply. Using the nut for a tie point for all those connections saved them having to add a large solder ring.
Murf and BrendaAnn, this is excellent timing! After a few months of having my 40-180 apart, it is time to put things back together. This conversation saved me from making a silly, yet costly mistake in putting those cans back in - thank you!
Murf, did you restuff those cans, or just put the new cap under the chassis? I was planning on restuffing the can, but decided not to when I figured that cap might need to be replaced in another 15 years or so...
Eric
Glad we could help.
Brenda straightened me out.
I just mounted them underneath. Much easier and I don't get many people flipping the radio over to look at the caps.
Good luck on yours and thanks again to Brenda.
murf
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
There are currently 1082 online users. [Complete List]
» 1 Member(s) | 1081 Guest(s)
