Mondial - thanks, exactly what I needed. I would bet that the coil I am now using came from a 71 or 91 with the old style tuning condenser, which probably had more capacitance than the newer, smaller tuning condenser used on the 91-126.
So...the coil will come out again soon, the tertiary winding (on a separate form mounted inside the main coil form) will be removed, and I'll remove some turns. I can see my having to do this two or three times before I get it to a point where it can be aligned. But I think I would rather go to the extra trouble and do this rather than making the 6A7 conversion at this point.
Progress report:
I remove the oscillator coil tonight (again). Pulled the tertiary winding from the center of the coil, and then proceeded to remove 10 turns from the tuned secondary winding. Reassembled and reinstalled in the radio, tack soldering the wires to it as I assumed it would have to come out again.
Results: 1200 kc now comes in at 120 on the dial - but the oscillator (high frequency) screw is still all the way out on the tuning condenser to achieve this. My SSTRAN, at 660 kc, comes in at 70 on the dial, and that is with the low frequency padder wide open as well.
So it appears some more turns need to come off.
I think tomorrow or Sunday, when I work on it again, I'll try just five more turns. I don't want to go too far, now that I'm getting close...
I also oiled the tuning condenser bushings/ball bearings, which helped the cutting out a great deal; it is nearly eliminated now. Perhaps after the oil has a chance to soak in, it will be even better.
More progress, if anyone's still reading:
I pulled the oscillator coil back out again. This time, I removed five more turns as planned. Reinstalled.
The 1200 kc signal from the signal generator was now coming in around 1140. This was a good thing, as I was able to (finally) turn the high frequency oscillator trimmer in somewhat to bring the signal back up to 120 on the dial.
Meanwhile, down the band...660 now comes in around 684 on the dial.
I think this is the best that I am going to achieve with this one, and have declared victory.  The 91 is very sensitive, even with a temporary 20 foot antenna strung along the ceiling of the basement. (I have yet to put up an outdoor longwire at this location; this will be a spring project.)
Things that remain to be done: New rubber bushings under the tuning condenser, giving the chassis a good cleaning, and installing an 8 inch speaker in place of the stock 10-1/2 inch speaker (this chassis came from a console, but will be going into a cathedral cabinet).
Threads: 273
City: Wilsonville
State, Province, Country: OR
Still reading   congrats on solving that oscillator coil problem.
Thank you, Bob!
Threads: 41
City: Shepherdsville, KY
Hi Ron
Somehow I missed this post until today. It is interesting about "modifying" the Osc. Coil. Good work.  Joe
Thanks, Joe
Back to doing some more projects around the house...while I wait for the six feet of snow (actually, the prediction is for 4 to 6 inches) to begin...
Threads: 16
City: Kokomo, IN
We already have more than 6" more like 8" and still falling.
Threads: 573
The maximum I have ever seen is about 4 or so feet high when I lived in central Russia, in 80s. This was not overnight, but temps being very low the snow accumulated. So when we pushed the car through a narrow plowed corridor the snow was at the level with the car's roof.
Threads: 92
City: Clayton, NC
Hopefully you get no snow.
Been reading too, as I have both a 91 and a 14 (late) on the "to do" list.
We only received around an inch of snow, but it's as cold as...well, you know. We went from 40 degrees around midday yesterday to below zero this morning, where it has basically remained since. Tomorrow it is supposed to reach the heights of 14 above. Brrr!
I'll look for a speaker for the newly repaired 91 chassis next. I have one...actually I have several...but I will probably have to swap field coils with the 10-1/2 inch speaker I have, as the 91 wants a speaker with a 3200 ohm field, and most of my K series speakers have 1100 ohm fields.
Threads: 107
City: Sheboygan Falls,Wisconsin
Glad to hear you got your 91 playing well Ron, congrats  . Mine is working well also, but still trying to get the shadow meter to work right.
Woke up this morning to -14 below with 25 to 35 mph winds! Wind chills of around -45 below zero  ! Had to take a personal day as my car refused to start, heck it would barely turn over!! Took over half an hour to pull the battery, as my car sits outside and I had to work in the wind. Fumble around 10 minutes then into the house to warm up and go out again! Finally got the battery in the house and on the charger. Hopefully a warm, fully charged battery will get her started tomorrow!
Kevin
Threads: 573
Ron
You could use a resistor (with proper power rating, which you probably know) in series as the field coil in 91 is not used as a filter.
What I do not understand there, if they use 2 speakers (I guess 2nd is an option) they plug the second field coil between the B+ and Chassis which (if the fields are similar) would create a nice divider and lower B+ quite a bit. Or is the second one some sort of a twitter and has a field of very high resistance?
Threads: 40
City: Las Vegas, NV
They seemed to like using a 1.1K and a 3.3K field on the dual speaker set ups.
There is a nice spreadsheet of Philco speakers in Riders volume 4 in the Philco section starting on page 4-44
John
Las Vegas, NV USA
LASJayhawk Wrote:There is a nice spreadsheet of Philco speakers in Riders volume 4
Also here, in Microsoft Excel format and covering 1929 to 1938 models:
http://www.philcoradio.com/phorum/showth...hp?tid=215
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)?
Budget constraints for Ham ...EdHolland — 01:43 PM |
My Philco 37-116 Restore
You're doing great.
I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM |
Hope you guys are still with me.
I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM |
Hello MrFixr55,
Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM |
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor!
Ron462ron — 08:08 AM |
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM |
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope.
May be time to crack that ...jrblasde — 07:27 AM |
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM |
Hi DConnant,
The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM |
The shield is on the 6H6.
It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM |
There are currently 1109 online users. [Complete List] » 1 Member(s) | 1108 Guest(s)
