DIAL STRING 38_15
Have not been able to find the Dial String for 38_15. I think it was on wrong and wrapped around the upper shaft. Here is my best guess. I saw a 38_14 on the site but could not verify the string. Thx in advance
http://s1289.photobucket.com/user/TROG99...d.jpg.html
I have been using hemp twine and 3/16" brads to secure the string to the dial. Any tips I will be doing this shortly.
Assuming that the tuner is in the fully meshed position in your drawing, I would add one turn around the pulley going counterclockwise. The tuning shaft should have at least 2 1/2 turns around it. No turns around the upper shaft, it's just there for tensioning.
YMMV
http://s1289.photobucket.com/user/TROG99...7.jpg.html
tHX BrendaAnnD I have the pic above now. So more like it?
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1106 online users. [Complete List]
» 1 Member(s) | 1105 Guest(s)
