Kolster K-120 Cap Bank Question
Just started going through this replacing capacitors and have hit a roadblock. On the bottom side there is a rectangular metal can that has Sprague 7337 on it with connections on the bottom. The other is on the top side with some of the values silk screened on the side but blocked by the tuning cap. Does anyone out here know anything about the Sprague unit to start? Any assistance would be helpful.
Have you look at the sch vs assy drawing what that block is and what values ar there? Sprague pretty much built capacitors so this is likely what it is. And on the drawing a number probably is assigned to it and then in the sch it probably shows what it is.
There are currently 1710 online users. [Complete List]
» 5 Member(s) | 1705 Guest(s)
AvatarAvatarAvatarAvatar
