Hello To All, Newbie here!
    Hello, today I picked up what I think is a Philco 42-400s got it for free. Now this is my first and have no idea where to start. The wires are frayed, the speaker cone is shot how ever the cabinet is in really good shape and I'm only missing two knobs! This unit does have a turn table but I would really love to get the radio to work.
Thanks All
Keith
from Youngstown,Ohio
Keith
Even if your speaker were in excellent shape and even knobs were present, forget about trying to plug it and see if it works.
You can start with seeing if all the wiring needs replacing (likely if it is rubber-insulated one) or not, and upon deciding that you have to:
1. Do the re-capping (change all capacitors except for mica ones)
2. re-carbing (changing all OUT-OF-SPEC resistors).
3. Making sure your transformer is OK and can output AC,
4. Test your tubes.
In the meantime you can send your speaker for being tended to, see the resources listed in this site (or others - they more or less list the same ones as there are only so many of them). I had good luck with The Speaker Shop, some people praise John's Vintage Radios in NJ.
Take it slow, enjoy it and learn in the process.
And - welcome!
Thanks Morzh! OH, I won't plug that baby in to many bare wires! I'm not very good with electronics that's why I'm not sure where to start.
Keith
"Do while you can"
Welcome to the Phorum Keith! Its a little hard to see from the photo but it looks like you might have a 42-1008P ( http://www.philcoradio.com/gallery/1942a.htm#aw ) What are the numbers on the chassis? You can get free schematics for Philcos at http://www.nostalgiaair.org/ and get better (clearer and more) information from Chuck Schwark at http://www.philcorepairbench.com/schematics.htm for just a few bucks.
Here's a recent thread with some starter information that you might find helpful. http://philcoradio.com/phorum/showthread.php?tid=8321
The 1942 Philcos had rubber coated wire that has, in most cases, crumbled by now and will have to be replaced in addition to those capacitors and resistors that morzh mentioned.
My only advice would be to make sure the power transformer is good in the radio before you send in the speaker to be re-coned. A bad transformer often is a deal breaker when making the decision to repair the chassis or save it as a parts chassis.
Herb S.
I tell you this - if a cabinet is good, and the radio is the one I want, although I will cuss and spat when I find out the power tranny is pushing dasies, I will be chugging along with it as you can always find a transformer that will satisfy the electrical and power requirements and fits inside, and then there are ways of securing it.
It is a hassle though, a totally unwanted one, that I agree with. Plus a possible $100 setback.
welcome keith
best to get a schematic off chuck I did very easy and clear to read .
the hardest part will be that beam of light and record cutter working again
sam
Hello keith.
Keith Welcome! This is the nicest forum on the planet! Only Good people here.
Hello Keith. Can't agree more with the others that are telling you to order a schematic from Chuck. I couldn't believe how much more information was in his for my set than in the one I obtained free online. Best money well spent! Take care, Gary
Hey Keith,
Here is a website that has lots of good basic information for newbies. I learned a lot there. Phil's Old Radios. Check it out at www.antiqueradio.org
Also, check out the You Tube radio restoration videos of Joernone. His videos are geared towards newbies as well.
The people here are really sharp and can answer most any question as well.
Good Luck,
Tom
Hi Keith!
I am a newbie to this forum as well and just so happens I have the same radio as yours. I restored it about 15 years ago and it sits in my livingroom and we listen to it all the time. It is a wonderful radio with fantastic sound! Yes, my record player works as well. It looks really cool when the record player works as that big pickup head glows from the light inside.
Good luck with your resto and if I can help just let me know.
Gregb
Welcome to the Phorum. Icon_wave
That really does look like a 42-1008 with the (sort of) rare and unique Beam Of Light phonograph. That was the first tube radio I ever repaired. It was a learning experience, and I've been fixing electronics professionally for over 25 years.
Every minute was worth it. I have the old radio bug now. Icon_e_geek
Though nowhere near an expert, I'm willing to help with any questions you may have.
My Philco 37-116 Restore
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
