substitute for a 32-7905N Audio Xformer?
I just posted a WTB on the want ads section but thought I'd ask a related question here too. Can anyone suggest an available, functional substitute for the audio output transformer used in a 38-690 (Philco p/n 32-7905N)? It would not have to be fused as the original is, just suitable for use with the 6L6 push-pull output.
Dave Perkins
Old Radios
Old Volvos
and homebrew beer !
Do you happen to know the ratio's and imp.?
Here are the pertinent specs:
32-7905
Primary impedance: 6000 ohms, center-tapped
Secondary impedance: 3.9 ohms
20 watts
The Hammond 1620A is a very close match - 6600 ohms to 4/8/16 ohms (you would want to use the 4 ohm output).
http://www.hammondmfg.com/pdf/EDB1620A.pdf
This transformer has screen taps that would not be used in this application - you would want to tape those leads up and leave them unused.
Thanks Ron !
Dave Perkins
Old Radios
Old Volvos
and homebrew beer !
Philco 42-1008 conversion kit
12' Philco
Shadow Meter Bulb
Shadow Meter Bulb
Model 28L
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
There are currently 4579 online users. [Complete List]
» 1 Member(s) | 4578 Guest(s)
