Philco 70 Resistor
Restoring a Philco Model 70 (Below B-22,000). Resistor (33) on parts list says 100,000 ohms (white, white, orange). Installed in two separate chassis I have is a 45,000 ohm (yellow, green, orange) resistor. Several other photos on internet of chassis all have same 45,000 ohm resistor installed. What is correct value? Should I leave the 45,000 ohm resistor installed or replace it?
I believe we are talking about resistor 30. A note on the schematic states Early production: 100,000 Ohms, Later production: 45,000 Ohms. http://www.philcoradio.com/tech/images/70a.jpg
M R Radios   C M Tubes
Thanks Steve. That solves the problem. Your schematic is not from Nostalgia Air which is what I was using. Where did you obtain the schematic? If you have the parts identification list that goes with this schematic, I would greatly appreciate that.
Thanks again
Dan Koczur
Dan, go to http://www.philcoradio.com/ or click "Home" near the top of this page. Our Phorum administrator Ron Ramirez has provided lots of useful information on Philco radios. Also check with Chuck Schwark at The Philco Repair Bench http://www.philcorepairbench.com/ Chuck has a service information pack with a very clear schematic that is well worth the $7
You can get clear schematic and parts listing info from Chuck Schwark at http://www.philcorepairbench.com/schematics.htm
In the meantime see: http://www.philcoradio.com/tech/images/70a.jpg for early models and http://www.philcoradio.com/tech/images/70b.jpg for later ones.
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1110 online users. [Complete List]
» 1 Member(s) | 1109 Guest(s)
