Model 20
There sure will be a difference, but the negative bias still should be there.
Hi Morzh
I thought you might like to see a picture of the speaker I was telling you about with the enclosed wiring.
Gregb
Wow. So even the voice coil is connected inside. Mine has original grommet (tell tell sign - very dry) and all tucked in except the output wires. They come outside. I guess in yor case they decided to be more of neatnicks than usual Icon_smile
There has to be some access to those wires. The output transformer has been replaced, perhaps by removing it there is access beneath it?
Yes, if you remove the transformer the wires will be underneath.
the speaker was repaired, I think - you could see the two insulators for the voice coil solder posts on the left of the transformer. I am not sure what happened but if they decided to connect short voice coil wires directly to the rigid transformer output ones, then no wonder the speaker sounds more rigid than it should.
I have now taken it apart and from what I can see it is all original. The solder looks just as old as every other connection in the set and everything has that factory look to it. All of the connections to the transformer are directly below it and I am sure all original. It is a Canadian made radio so possible we Canucks did things a little different back in the day, as will still do.
Gregb
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 755 online users. [Complete List]
» 1 Member(s) | 754 Guest(s)
