Putzing around with 90's detector.
I have tons of time on my hands (well, I am on vacation now and will be for another week or so) so I've decided a couple of hours ago to see if anything that I could do to that plate detector, that would improve its performance.
As I have written in the main 90 topic, I found out that the buzz (hum) I get when tuned in to some stations seems to misbehave more in this radio and my 20, this I think is one of the reasons for the distorted sound.
Now, I thought maybe some optimization could at least improve something. I could give you heads up before you read it all, that nothing I did really mattered, at least to my ear.
Here's what I tried:
1. I tried to replace the cathode cap in the detector with a smaller capacitance. It is in fact recommended that it be about 100 - 500pF and not the microfarad range caps that are usually there. This would reduce the gain but according to that article is supposed to improve the results.
Well, it did reduce the gain all right, but did nothing to improve the output quality.
2. I shorted that inductance in the plate filter. Heard some hum. No improvements.
3. Eventually I tried to decrease that DC blocking cap down to 1000pF as it was initially in the sch. To my surprise the ouput did not even change. So one thing I can tell, a 1,000pF cap works the same way (to the ear) as 0.01uF (10,000pF) one does.
4. Last thing is, whatevert literature I read so far, including looking at the schematics with a very similar plate detectors in one of the 70 series and in 20 (exacftly the same) the RF cap in the plate is in hundreds....220pF or so. In the literature it says from 150 or 200pF and up to 1000pF. So 35pF is not enough, but it is a good question again, whether or not it would noticeably change the sound.
Ifv I do anything else I will post it here.
Just for laughs try bypassing the plate det and drop in a 1N34. See how diode works.
I think it may work well.
It would require a lot of circuit redesign to use a 1N34 in this particular style of detector. However, if you feel up to it, you could experiment with the plate and cathode resistors' values to alter the curve on the detector.
I think I will first get that transformer I ordered today, it is a pushpull OT20PP from Musical Matt, whose 8 watt SE I successfully used for my Zenith.
The OT20PP is 6K6/8K to 4/8/16 Ohm so I can match my voice coil to the tubes' requirements pretty close as my coil is 6.2 Ohm and so the impedance is somewhere there. And I know this is not the cone or the coil or alignment by now. So when I eliminate that I'll see if I want to putz with it some more or I will be content with authentic working radio.
Well, after that fiasco with those two line transformers, I got the one from AES (tubesandmore.com) which is 17 bucks and is a matching transformer, 8 Watts, exactly what I need, and it installs easily - all holes match.
Sounds as good as MusicalMatt's transformer above and much better than the one that was installed here by the previous guy.
Listening to the "Whiter shade of Pale".
Well today was good, 2:1.
First Radio restoration
There are currently 1356 online users. [Complete List]
» 1 Member(s) | 1355 Guest(s)
