Books on restoring Tube Radios
A while back I saw some people recommend a couple books on learning to restore tube radios. I cant seem to find the thread though. I think one of them was called "The All American Five". Can anyone give me a couple suggestins on good books to learn about electronics restorations? Thanks for your time.
A book titled as "AA5" will probably have, well, AA5s in it. And with AA5, you restored one (OK, two) of them - you pretty much know them all. Even those made in Latvia (can I still call them AA5 or should I go like AL5?).
Somehow I think there are not tons of those out there, and if you look at two or three and look at reviews (and solicit opinions) you will know what you need.
Makes sense about the AA5 book...On the other thread there were a few suggestions, hopefully someone will suggest a few for tube radio restorations.. Thanks.
I looked up "The All American Five" on Amazon. Amazon, of course, suggested other books on the topic. Most of them have reader reviews. You might find something you want, at the level you want.
The book I started with is "Elements of Radio Servicing" by Marcus and Levy, 1947. It's not about restoring, exactly, and it doesn't address cabinet restoration, but it is a thorough text book on understanding, diagnosing, and repairing basic tube radios. It addresses test equipment, diagnosis, alignment. You can download a copy in six pdf files for free from here http://www.antiqueradios.com/archive.shtml It might be kind of expensive to print all 473 pages, if you don't want to read in on your computer, but I'm told the book is often available on ebay.
John Honeycutt
Warren I think this might be the thread you were thinking of. It lists some books.
http://philcoradio.com/phorum/showthread...7#pid54007
Yes, that looks like the thread I was thinking about. Guess im not very good at searching for a thread. Thanks for your help.
Philco 91 Restore Code ??
Can someone tell me if my 42 tubes are connected triode or pentode in fixed or cathode bias? How could I tell by looking...dconant — 10:47 AM
Philco 40-120C Restoration
Hello David, that is great news about the tubes source being local ! Sounds like you got good start on the radio . ...radiorich — 09:41 AM
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
There are currently 3989 online users. [Complete List]
» 1 Member(s) | 3988 Guest(s)
