Help with identifying model number
Hello,
I think this may be either a 42-762 or 42-788. I am unsure because the speaker and dials are set up similar to the 762, but the top of the box looks more like a 788. Any help would be appreciated.
It's a post war model actually, from the early 195os. Have a look under the 1953 Philco models, it's probably a 53-960, one of the last Philcos to have spread band shortwave on it, at least for the domestic U.S market. I think that the last to have it was a transistor portable.
Arran is correct - 53-960, the only Tropic-style radio that was sold in the USA rather than being sold as an export model.
http://www.philcoradio.com/gallery/1953.htm#ab
Interesting, by 1953 Philco (USA) was no longer producing Tropics for export; they had turned that over to their UK and Argentina subsidiaries by then.
Philco 91 Restore Code ??
I knew that Fluke was the Cadillac so with that in mind what Fluke would you recommend I get?dconant — 03:53 PM
Yep. 10W is probably enough. Also, if the meter measures Farads, then it should also have that "Delta" button...morzh — 02:38 PM
I measured the current through the resistor I am using as a replacement for the speaker field coil and got 40ma. So that...dconant — 02:32 PM
No I'm not saying I don't own a DMM. I have a CCC one (Thsinde 18+). I forgot that could read caps. I did purchase a Flu...dconant — 02:28 PM
Are you telling me you do not own any decent DMM, that can measure capacitances from a few pF and up? Even todays CCC (C...morzh — 01:44 PM
Restoring Philco 96
Well, selectivity today, with stations disappearing, is not such a problem for TRF as it likely used to be. Although wh...morzh — 01:42 PM
Mike I did that already and can't really get any kind of reading. My little Honeytek A6013L reads 0 on all scales. One s...dconant — 01:38 PM
New member
Well, to be frank, when it comes to radios, especially the older types, a person with no electronic background could be ...morzh — 01:33 PM
Restoring Philco 96
Thanks for mentioning the video you had uploaded. Somehow I missed that post. Just watched your video, and it sounds to ...jrblasde — 01:28 PM
Restoring Philco 96
Joseph well, for now we will have to get by the video I have made, as the final video would not be made before I get a ...morzh — 01:04 PM
There are currently 4992 online users. [Complete List]
» 2 Member(s) | 4990 Guest(s)
