1930s Philco Dial Material
Has anyone found any modern plastic material that is close or identical with the color of the original Philco dials of the 1930s era? I see this same type material used on some other brands as well. Any ideas or sources?
Joe
Ask Mark Oppat.....he makes repros.
+1 Icon_thumbup
Oppat's dials are very good repops. I have NEVER been disappointed by them.
Morzh and TA Forbes;
Thanks for that information. I have sent a query to Mark and hope to hear from him soon. I am trying to reproduce a bandspread dial for a Hallicrafters SX-25 I am restoring.
Cheers!
Joe
Joe,
I hope you're checking the phorum again..
did you ever hear back from Mark? we had a little email flurry back and forth last year about dials for my 624 & 610. at the time, he was no longer printing them because the company making the material either went out of business or quit making the material.
I didn't get in to super detail with him about the company, but my assumption was he got it from the same supplier Radiodaze was. they have since found a new supplier. I haven't followed up with him on it since. I ended up using the 610 dial scale I purchased from Radiodaze (that I didn't like because it wasn't an exact replica like mark's was). kind of funny that I swapped the 610 and 624 dial scales because I was more interested in having my 610 dial scale be authentic looking. btw.. I was able to adjust the alignment of both my 610 or 624 to accommodate each others slightly different dial scales.
Bret;
Yes that is basically what Mark told me too. He also said that to do a run for the more limited items such as the 624 7 610 or the Hallicrafters SX-25 would require a rather substantial order from a group of people to justify him going to the effort. I managed to acquire a set of dials for the SX-25 from a restorer on the Antique Radios forum group. It might still be a good idea to contact Mark again and see if the situation has resolved itself since our last contacts with him. See you at VPRS Saturday?
Joe
That's a shame.. His repro's are the best. Yup, I'll be there tomorrow.. I'm hoping that Jim can help me locate a vibrator for my 624. and I need a couple of knobs.
by the way, I don't mean to belittle radiodaze dials.. they're very good. I just like his better. Besides, John over @ RD worked with me to get the 40-125 decal set done, for cheap, as they ended up offering them for sale immediately.
I was just in contact with Mark for a dial scale for my 37-611 and he is still out of material and at the moment has nothing lined up. He told me to check back mid summer and see how he made out with finding a new supplier. This is very unfortunate!
Gregb
That is bad news. Mark does great work. I hope he can get a new supplier.
Philco 42-390, code 121 speaker
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A...captainclock1988 — 03:43 PM
Using a 5W  1.5k  ceramic resistor in place of the field coil and using a 4 ohm PM speaker, I was able to bring the radi...Stevelog — 02:57 PM
Philco 60 Squealing
I have taken out the 2nd IF and found a problem or not. I believe the coils are litz wire. There is a very small strand ...dconant — 02:13 PM
Philco 6K7
I am restoring a Philco 37-60. The am reception is very good, but the shortwave is very weak. Run 6 Philco removes the g...bobbyd1200 — 01:35 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A5...MrFixr55 — 06:48 AM
There are currently 5196 online users. [Complete List]
» 4 Member(s) | 5192 Guest(s)
AvatarAvatarAvatarAvatar
