Need parts list for 41-285
Hi everyone,
First time to the phorum. I am working on a Philco 41-285 and could really use the parts list portion of the service manual (or the whole thing, really, if it's a good clear scan). All I can find is the basic schematic; I could really use the parts list. Thank you!
I'd suggest you buy a copy of the original Philco schematic and service package from Chuck Schwark at this site: http://www.philcorepairbench.com/ (See "schematic info" on the sidebar on the left.)
They are clearly copied and often include large format schematics, production changes and so on that you might not get from the poor copies available for free.
They are inexpensive and well worth it, IMHO.
It is a little odd that the free schematic scans for the 41-250, 280, 285, 290 series of radios don't have parts lists. I've found the same thing.
John Honeycutt
Thanks John. Here's a link that you all might want; though it is obviously not comprehensive, I found complete schematics, parts lists etc. for many different Philcos, including mine. Super clear scans, too:
http://www.audiophool.com/Philco.html
Diverted, I've tried this site before, but I can never get the djvu files to work. There's probably a djvu viewer out there that works, but none have ever worked for me. What's your secret?
John Honeycutt
John, there is no secret from my end. I just downloaded the file in that DJVU (?) format. When I tried to open it my Mac automatically asked if I wanted to instal DJVU viewer. I clicked yes, it installed and now I can read the files.
If you are having problems with this, I can help you. The program converts the files into PDF. If there is a specific file you need, let me know. I will download it, convert it and email it back to you.
Ted
Ha, ha, I had no sooner sent my last post about having trouble with DJVU files than I thought, "I bet Diverted has a Mac." I'm sure it makes some things easier. I'm using one of Bill Gate's products. I'm reasonably sure I can figure out how to open and convert DJVU files if I Google it, but it sure would be cool to have the machine do that for me.
Thanks for the offer to convert DJVU files for me. There aren't any I need at the moment, but I might take you up on it later.
John Honeycutt
Any time. I'll make PDFs for anybody here who can't convert/open these files.
Also, John, try this link. It looks like a pretty simple PDF converter. Good luck.
http://www.pdflite.com/djvu-to-pdf
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
Where is the crack? A cracked tube that has air inside will turn opaque once turned on. Perhaps it is a scratch, nogt a...morzh — 09:50 AM
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
There are currently 938 online users. [Complete List]
» 1 Member(s) | 937 Guest(s)
