Bakelite line filter caps in 41-285
Threads: 13
City: Bristol, RI
Hi all:
Newbie question. On chassis 41-285, why are the two .01 mfd line filter caps along the AC line installed in that odd grounded bakelite box, then buried in tar? I assume the best way to redo them is melt that goop and clear everything out? Do they need to stay in the box for some kind of shielding? Etc? Or can I mount new caps outside it? Thanks,
Ted
Threads: 10
City: Columbia, SC
Philco put capacitors in those blocks, and filled them with tar. It gave them mounting points for other wires and made the chassis cleaner. I have no idea why they had to use tar...
Those two caps filter out noise in the AC line, and give you a cleaner power supply. Each goes to one leg of the line and ground. They should technically be safety caps, but regular ones are usually fine. http://www.justradios.com/safetytips.html
To remove the tar 'plug', cut the four little wires in the rivet holes on the top of the block (I use a razor blade), then heat it with a heat gun on the top and sides. After 20 seconds, use a small screwdriver to push the contents out the bottom. It is a much better idea to mount them inside the old block, both for safety and aesthetics.
Over at the Philco Repair Bench there are articles about the contents and connections of various blocks, and how to restuff them.
(This post was last modified: 02-11-2014, 11:30 PM by skyscraper.)
Threads: 574
In addition to what Skyscraper has noted,
1. heat on "Low" using a heatgun. In case you do not have "Low" (some heatguns have cool and hot, and some Low and High) use high from a distance. I use "Low" for 10-15 sec, equal time every side.
2. Use a blunt instrument like a small Allen wrench. Sometimes the tool gets in between the two caps that are inside and if it is any sharp it can cut through the warm tar and you get a hole and the tar block still stays inside.
3. If it resists, heat one more time, do not force much.
4. Leave the cap in place (do not unscrew) when you do it and do not unsolder the wires - makes it so much easier, just cut the think wires coming from inside the block (!!!! - very important unless you want to deal with a mess).
5. No regular caps are NOT fine. Use only Y-rated capacitors.
Threads: 34
City: Raleigh, NC
I'm no expert, but I think Philco potted the caps to keep any moisture from degrading the line filter caps. Since they were connected line to ground, they'd have more catastrophic effects if they shorted or leaked than most other caps in the chassis.
I use X/Y caps from Just Radios, which are disk-shaped. They fit fine, except they stick out the open bottom of the Bakelite box just a tiny bit, not enough to see or to interfere with the fit.
Most of us leave the Bakelite block in place after replacing the caps because it's a convenient place to connect AC and transformer lines to those filter caps, and to connect one or two things nearby to ground. You could do the same thing with a terminal strip, I suppose, but the Bakelite shell looks good.
John Honeycutt
Threads: 574
"Catastrophic" meaning "becoming the death cap" if someone touched the chassis and Earth at the same time.
Threads: 275
City: Wilsonville
State, Province, Country: OR
Hi Ted welcome to the Phorum. Some Bakelite block cap info that you will find useful can be found here: http://www.philcoradio.com/tech/blocks.htm . A tutorial on X and Y safety caps can be found here: http://www.justradios.com/safetytips.html
Threads: 85
City: Annapolis, IL
State, Province, Country: USA
Ted, check out my bakelite cap rebuild in the thread "70 rebuild". I just finished those and have a few pics posted. Also some useful info in "70 restoration" thread by "morzh".
Tim
Threads: 13
City: Bristol, RI
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM |
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial. The first s...HowardWoodard — 01:01 AM |
Well, finding a short is easy.
Like I said, disconnect the transformer's secondary windings and see if it persists.
If...morzh — 09:48 PM |
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM |
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM |
Rogers Majestic R-646
Kinda weird to see both open
Nothing weird if you remember that this radio is about 100 years old :)Vlad95 — 07:49 PM |
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM |
Thanks Morzh
Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM |
Well...pull out every single load of the transformer. For every winding.
Unsolder if needed.
Then re-do your dim bulb....morzh — 07:02 PM |
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM |
There are currently 1000 online users. [Complete List] » 1 Member(s) | 999 Guest(s)
