16b restoration help needed
Just finished my first restoration on a 16b. I replaced all the caps and whatever resistors needed to be replaced. Also had the tubes tested and the on off volume control switch is new ( built by Mark at old radio parts ). When I first turned it on the volume was very high and could not be controlled. I realized the pot was not grounded, so I fixed that. Now the volume does not get very loud at all. No where near as loud as it was when I first had it on. Any ideas? The only cap I haven't replaced is the one on the volume control knob, but it seemed to be ok when I tested it on my multimeter. Haven't started the alignment yet. Could that be the problem?
Are you sure its wired right? If it was full volume before that makes me think the wiper wasnt wired in and now with a ground its shorted
First of all, check your volume pot.
Report back.
It ended up being the capacitor. The only one I didn't replace because I thought it
would be good. Thanks for the reply though.
There's a lesson.
Folks wisdom has its merits.
Replace'em all.
Never ever trust a 70-80 year old capacitor no matter what your meter tells you. It WILL come back to haunt you as you now know.
Gregb
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
There are currently 1333 online users. [Complete List]
» 1 Member(s) | 1332 Guest(s)
