Philco 46-1226 restoration.
I just purchased a Philco 46-1226 radio and am looking for advice on fixing it. Im getting no sound out of the speaker, but everything else including the turntable is coming on. Any ideas of where I can start looking for the problem? This is my first time trying something like this so I have no clue. Thanks
Hello Swesterman.
I own one of the bigger brother of your radio, the 47-1230. First thing first you should ensure it is safe to operate your radio. As surprising as it may sound, 60 years old capacitors can be dangerous.
the first piece of advice would be there: http://www.philcoradio.com/tech/plugin.htm
make sure you won't set your house on fire when applying power on the radio.
Then, look for the schematics. It is available online.
An easy test to know if the power and amp section works on such radio is to connect "anything" trough the phono connector - its modern-RCA connector compatible and will accept the input as long as you're set in phono mode (left-most preset button)
Something you will want to consider is to change all paper/wax capacitors from your radio, as they are no longer good.
Hoping this helps.
-Mars
Welcome to the Phorum!!
There is a Philco Service Bulletin on that model available here: http://www.audiophool.com/Philco.html
If you are brand new to vintage radios, this might be helpful: http://www.antiqueradio.org/begin.htm
...and here's a thread that might help: http://philcoradio.com/phorum/showthread.php?tid=2673
There are currently 1646 online users. [Complete List]
» 3 Member(s) | 1643 Guest(s)
