KENT 422
I have a Kent 422 ,little metal 4 tube radio ,I 've got it playing,but would like to know if this can be found in "Riders" not a real good preforming set,so far ,has no IF tube? need alinement, IF 455?
I don't see it in Rider Vol 1-23, nor in Beitman. Seems it may be a tough schematic to find; the Radiomuseum is looking for one: http://www.radiomuseum.org/r/kent_422.html
This fellow has one, you might try emailing him: http://web.eecs.umich.edu/~srs/Antiques/
That looks like a re-badged Arvin.
Have a look at this:
http://www.nostalgiaair.org/PagesByModel...012516.pdf
I think this is an Arvin radio, THANKS for the tip on the schematic BRENDA that sure looks like my radio! I got it to play somewhat better got it tracking good ,loose the signal on lower end,mixer/detector problem?
This radio plays like it looks CHEAP! ,I think by using the name KENT they though they could cash in on the ATWATER KENT name ,but AK never built anything this cheap!
In a Russian prison/criminal argot "Kent" means "a pal". Icon_smile
Bill,
These sets are a bit tricky to align properly, and if not done right, you won't have any low end at all.
You pretty much have to ignore the dial calibration on the low end of the dial. Set your signal generator to 600 KHz then find the signal on the radio. Once you find it, you need to tweak the outer rotor plates on the antenna section. By pulling the cutout sections out a bit or pushing them in a bit, you'll change the resonance of the antenna section to bring it into alignment with the LO. Then use the trimmer on the tuner to bring both the LO and Antenna to match the dial at about 1400 KHz. You may have to do this several times.
How did they calibrate it at the factory? Same way?
Philco model 40-100
That was part pf what began my interest in tube battery radios, the variety of circuit designs, especially by Grimes-Pho...Arran — 02:37 PM
Phill; I had a look at my Riders "Specialized" car radio books yesterday, I don't have one that covers Stud...Arran — 01:50 PM
Philco Model 249 made in England
Thanks for the information MrFixr55.   It's tube amplification and not solid state. TOMfklown — 11:27 AM
Well, I’ll be! I learned something.jrblasde — 11:03 AM
Yes, Garrard was well-regarded for its standalones.morzh — 10:48 AM
Quite the interesting stories, sir! Somewhat reminds me of my first job out of school (not that I worked in a similar fi...jrblasde — 09:33 AM
Philco model 40-100
Arran, I restored 2 Canadian battery-crank telephones for a friend a while ago, a Northern Electric (Canadian version of...MrFixr55 — 08:04 AM
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
There are currently 907 online users. [Complete List]
» 2 Member(s) | 905 Guest(s)
