Philco 39-30 Pushbutton Removal
The pushbuttons are too short on the Philco 39-30 ( 1 1/8 inches long ). New pushbottons have been ordered ( 1 5/8 inches long ). How do you remove the old push buttons? I tried to pull them hard but did not want to break anything.
Thank you,
nv3g
Oscar
These pushbuttons should just slide on and off snugly. If they were replacement buttons, some one may have glued them on. Use some nail polish remover to unstick them. If they are the original buttons, they may be just stuck on from age. Use a pair of pliers to crack them apart and clean off shafts to install new ones.
The pushbuttons on my 39-25 were in such bad shape they crumbled easily and fell off. The new reproduction buttons will just slide on.
Hello! I actually just joined so this is my first post and I'm stuck and have a question. I have a 46-1209 and I can't find replacement pushbuttons anywhere I am only in need of one of them. I figured since you guys are talking about removing them and installing new ones maybe you would know where my specific model replacement s might be found thanx!!! Btw maybe I'll post what I am doing with mine it might interest some
Welcome to the Phorum Boz. I don't know if anyone makes a reproduction pushbutton for that model but the best sources for pushbuttons and knobs are the folks listed here: http://www.philcoradio.com/resourceb.htm#l . Try each one until you find someone who happens to have one. I've personally worked with Dave, Julie and Mike. John Kendall has some other 46-1209 parts if you find you need them, though he seems to have sold out of his pushbuttons (type 46-1209 in the search box).
Thank you I will do that when I have a few moments! ! I've had a project in mind that I've wanted to do for years but what I'm doing might drive you guys crazy!!! I don't know if it's rude but maybe I'll start a thread about it . Again thanks for the reply and I did not me to thread jack at all.
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
There are currently 1207 online users. [Complete List]
» 3 Member(s) | 1204 Guest(s)
